주요 콘텐츠로 건너뛰기
Dell Inspiron 17R-5721 Speaker Replacement
필요한 것
  1. Dell Inspiron 17R-5721 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Dell Inspiron 17R-5721 Speaker Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17R-5721 Speaker Replacement: 2 단계, 이미지 2/2
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Dell Inspiron 17R-5721 Speaker Replacement, Access Panel: 3 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
    • These two captive screws will loosen but will not separate from the panel.
  4. Dell Inspiron 17R-5721 Speaker Replacement: 4 단계, 이미지 1/1
    • Using a spudger, pry into the gap in the plastic revealed by loosening the screws.
    • Lift off the access panel.
  5. Dell Inspiron 17R-5721 Speaker Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the three 5 mm screws securing the hard drive to the laptop.
  6. Dell Inspiron 17R-5721 Speaker Replacement: 6 단계, 이미지 1/1
    • Grabbing from the left of the hard drive, slide the part to the left and pull up, lifting it away from the machine.
  7. Dell Inspiron 17R-5721 Speaker Replacement, RAM: 7 단계, 이미지 1/1
    • Using your fingers, separate the metal tabs located on the left and right of each stick of RAM by pulling them apart from each other.
  8. Dell Inspiron 17R-5721 Speaker Replacement: 8 단계, 이미지 1/1
    • Pull each RAM stick out of the machine, separating each piece from its respective slot.
  9. Dell Inspiron 17R-5721 Speaker Replacement, Keyboard: 9 단계, 이미지 1/1
    • Open the laptop to reveal the keyboard.
    • Using a plastic opening tool, pry the keyboard free from the palmrest assembly at the plastic tabs located across the top of the keyboard.
  10. Dell Inspiron 17R-5721 Speaker Replacement: 10 단계, 이미지 1/1
    • Once free from the palmrest, flip over the keyboard.
    • Unplug the ribbon cable connecting the keyboard to the motherboard.
    • Remove the keyboard.
  11. Dell Inspiron 17R-5721 Speaker Replacement, Palmrest Assembly: 11 단계, 이미지 1/1
    • On the bottom of the laptop, use the Phillips screwdriver to remove nine total 5 mm screws from the following locations:
    • Four screws at each corner of the laptop’s bottom panel
    • Two screws within the battery slot
    • One screw to the left of the hard drive
    • Two screws located below the RAM
  12. Dell Inspiron 17R-5721 Speaker Replacement: 12 단계, 이미지 1/1
    • Using your fingers, unplug the two palmrest ribbon cables found at the bottom left of the integrated keyboard’s slot.
  13. Dell Inspiron 17R-5721 Speaker Replacement: 13 단계, 이미지 1/1
    • Use the metal spudger at the bottom-right corner of the palmrest’s faceplate to pry underneath the plastic casing and separate the palmrest from the laptop’s bottom plastic shell.
    • Once the spudger has leverage between the two halves of the case, work the tool around the right, bottom, and left edges of the palmrest, prying the top from the bottom at around every half-inch.
    • Lift off the palmrest assembly.
  14. Dell Inspiron 17R-5721 Speaker Replacement, WLAN Card: 14 단계, 이미지 1/1
    • Disconnect the two antenna cables connected to the WLAN card.
  15. Dell Inspiron 17R-5721 Speaker Replacement: 15 단계, 이미지 1/1
    • Use the Phillips screwdriver to remove the single 3 mm screw securing the WLAN card to the laptop.
    • Remove the WLAN card.
  16. Dell Inspiron 17R-5721 Speaker Replacement, Motherboard: 16 단계, 이미지 1/1
    • By hand, unplug the four ribbon cables attached to the motherboard from the following locations:
    • The top-right
    • The top-left, beneath the WLAN card
    • The bottom-right
    • The bottom-left cable, attached to the speakers
  17. Dell Inspiron 17R-5721 Speaker Replacement: 17 단계, 이미지 1/1
    • Using a Phillips screwdriver, remove a total of five screws (two 3mm, five 5mm) from the locations marked on the image.
  18. Dell Inspiron 17R-5721 Speaker Replacement, Speaker: 18 단계, 이미지 1/1
    • Using the Phillips screwdriver, remove the four wide screws (2mm wafer) holding both the left and right speakers in place.
    • Despite the heads of the screws being wider than most others in the machine, the same #000 bit will still properly unscrew these.
  19. Dell Inspiron 17R-5721 Speaker Replacement: 19 단계, 이미지 1/1
    • Remove both the left and right speakers by hand.
    • Be careful to avoid pulling the two apart, as they are connected via an integral cable.
결론
Thomas Griffin
회원 가입일: 03/21/19
915 평판
안내서 9개 작성하였습니다
UMass Dartmouth, Team S2-G6, Bailey Spring 2019 UMass Dartmouth, Team S2-G6, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G6
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 225
