주요 콘텐츠로 건너뛰기
Dell Inspiron 17R-5737 Access Panel Replacement
필요한 것
  1. Dell Inspiron 17R-5737 Access Panel Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Access Panel Replacement: 2 단계, 이미지 1/2 Dell Inspiron 17R-5737 Access Panel Replacement: 2 단계, 이미지 2/2
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Access Panel Replacement: 3 단계, 이미지 1/2 Dell Inspiron 17R-5737 Access Panel Replacement: 3 단계, 이미지 2/2
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
  4. Dell Inspiron 17R-5737 Access Panel Replacement, Access Panel: 4 단계, 이미지 1/1
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
결론
Mack Chabot
회원 가입일: 10/18/17
645 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 UMass Dartmouth, Team S3-G7, Bailey Fall 2017 회원
UMASSD-BAILEY-F17S3G7
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 335
