소개
This guide will walk you through removing and replacing your Dell Inspiron 17R-N7110 RAM stick(s). You will be handling delicate electronic components during this process, so be sure to wear the anti-static wrist strap for this replacement.
필요한 것
Place the laptop on a flat surface with the Dell logo upside down.
Flip the laptop over. The battery will be in the top center.
There are two small plastic prongs to the sides of the first RAM stick. Push the prongs away from each other to release the RAM stick.
Gently remove the RAM stick.
If your laptop has a second RAM stick located underneath the first one, repeat this step to remove it.
다른 2명이 해당 안내서를 완성하였습니다.
