주요 콘텐츠로 건너뛰기
Dell Inspiron 3148 CMOS Battery Replacement
필요한 것
  1. Dell Inspiron 3148 CMOS Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Inspiron 3148 CMOS Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 CMOS Battery Replacement: 2 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 CMOS Battery Replacement: 3 단계, 이미지 1/2 Dell Inspiron 3148 CMOS Battery Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 1/3 Dell Inspiron 3148 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 2/3 Dell Inspiron 3148 CMOS Battery Replacement, CMOS Battery: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, lift the exposed edge of the CMOS battery upward.
    • Once the CMOS battery has been loosened, remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Gravelle
회원 가입일: 10/23/18
837 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 20
전체 시간: 272
