주요 콘텐츠로 건너뛰기
Dell Inspiron 3148 Fan Replacement
필요한 것
  1. Dell Inspiron 3148 Fan Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Inspiron 3148 Fan Replacement, Back Panel: 1 단계, 이미지 2/2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Fan Replacement: 2 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Fan Replacement: 3 단계, 이미지 1/2 Dell Inspiron 3148 Fan Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 Fan Replacement, Fan: 4 단계, 이미지 1/3 Dell Inspiron 3148 Fan Replacement, Fan: 4 단계, 이미지 2/3 Dell Inspiron 3148 Fan Replacement, Fan: 4 단계, 이미지 3/3
    • If there is tape on your fan, remove the tape.
    • Remove the two 2mm screws on the fan enclosure using the Phillips #00 screwdriver.
  5. Dell Inspiron 3148 Fan Replacement: 5 단계, 이미지 1/2 Dell Inspiron 3148 Fan Replacement: 5 단계, 이미지 2/2
    • Unscrew the three 4mm screws holding down the heat sink of the fan using the Phillips #00 screwdriver.
    • The three 4mm screws found in the heat sink will remain attached to the heat sink. This is okay as long as they are detached from the motherboard.
  6. Dell Inspiron 3148 Fan Replacement: 6 단계, 이미지 1/1
    • Use the tweezers to gently pull the power supply cable from its port.
  7. Dell Inspiron 3148 Fan Replacement: 7 단계, 이미지 1/1
    • Grasp the fan and lift upward. Remove the fan from the device.
결론
Christopher Gravelle
회원 가입일: 10/23/18
837 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 162
