소개
Are you experiencing problems with loading files and other applications on your computer? Consider using this guide to replace the hard drive.
필요한 것
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
If there is a piece of tape connecting the hard drive and a small power cord, remove the tape.
Using the Phillips #0 screwdriver, remove the two 4mm screws.
