주요 콘텐츠로 건너뛰기
Dell Inspiron 3148 Hard Drive Replacement
필요한 것
  1. Dell Inspiron 3148 Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Inspiron 3148 Hard Drive Replacement, Back Panel: 1 단계, 이미지 2/2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Hard Drive Replacement: 3 단계, 이미지 1/2 Dell Inspiron 3148 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 Hard Drive Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
  5. Dell Inspiron 3148 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Using the iFixit opening tools, lift the battery out of its housing.
  6. Dell Inspiron 3148 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Once loosened, use your fingers to lift the battery up and out of its housing.
    • There is a small cable which sits in a rut in the top of the battery. Ensure that it is pushed out of the way before removing completely.
  7. Dell Inspiron 3148 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Remove the battery completely.
  8. Dell Inspiron 3148 Hard Drive Replacement, Hard Drive: 8 단계, 이미지 1/3 Dell Inspiron 3148 Hard Drive Replacement, Hard Drive: 8 단계, 이미지 2/3 Dell Inspiron 3148 Hard Drive Replacement, Hard Drive: 8 단계, 이미지 3/3
    • If there is a piece of tape connecting the hard drive and a small power cord, remove the tape.
    • Using the Phillips #0 screwdriver, remove the two 4mm screws.
  9. Dell Inspiron 3148 Hard Drive Replacement: 9 단계, 이미지 1/3 Dell Inspiron 3148 Hard Drive Replacement: 9 단계, 이미지 2/3 Dell Inspiron 3148 Hard Drive Replacement: 9 단계, 이미지 3/3
    • Notice: there is a small data cable connecting the hard drive to the motherboard. Do not attempt to lift the hard drive all the way out before removing this cable.
    • Lift the hard drive slightly out of the device.
    • Grasp the head of the cable, not the cable itself.
    • Pull away from the hard drive, removing the data cable. The hard drive may now be fully removed.
결론
Christopher Gravelle
회원 가입일: 10/23/18
837 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 462
