소개
Is your computer experiencing problems with connecting to the Wi-Fi or the internet? Consider using this guide to replace the WLAN card in your device.
필요한 것
Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
Flip the device over so the backside is facing you.
Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
다른 한 분이 해당 안내서를 완성하였습니다.
