주요 콘텐츠로 건너뛰기
Dell Inspiron 3148 WLAN Card Replacement
필요한 것
  1. Dell Inspiron 3148 WLAN Card Replacement, Back Panel: 1 단계, 이미지 1/2 Dell Inspiron 3148 WLAN Card Replacement, Back Panel: 1 단계, 이미지 2/2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 WLAN Card Replacement: 2 단계, 이미지 1/1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 WLAN Card Replacement: 3 단계, 이미지 1/2 Dell Inspiron 3148 WLAN Card Replacement: 3 단계, 이미지 2/2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: 4 단계, 이미지 1/3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: 4 단계, 이미지 2/3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: 4 단계, 이미지 3/3
    • Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
    • Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
    • The card should pop right up once the screw is removed.
  5. Dell Inspiron 3148 WLAN Card Replacement: 5 단계, 이미지 1/1
    • Remove the two wires by pulling them upward, away from the WLAN card.
  6. Dell Inspiron 3148 WLAN Card Replacement: 6 단계, 이미지 1/2 Dell Inspiron 3148 WLAN Card Replacement: 6 단계, 이미지 2/2
    • Using your fingers, pull the WLAN card up and away from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Gravelle
회원 가입일: 10/23/18
837 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G2
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 15
전체 시간: 287
