주요 콘텐츠로 건너뛰기
Dell Inspiron 3501 Back Cover Replacement
필요한 것
  1. Dell Inspiron 3501 Back Cover Replacement, Unfasten the back cover: 1 단계, 이미지 2개 중 1개 Dell Inspiron 3501 Back Cover Replacement, Unfasten the back cover: 1 단계, 이미지 2개 중 2개
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use the Phillips screwdriver to remove the seven 6 mm-long screws securing the back cover.
    • Use the Phillips screwdriver to loosen the two captive screws.
  2. Dell Inspiron 3501 Back Cover Replacement, Unclip the front corners: 2 단계, 이미지 2개 중 1개 Dell Inspiron 3501 Back Cover Replacement, Unclip the front corners: 2 단계, 이미지 2개 중 2개
    • Insert an opening pick between the bottom-left corner of the back cover and the laptop body.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when each clip releases.
    • Repeat this procedure for the bottom-right corner of the back cover.
  3. Dell Inspiron 3501 Back Cover Replacement, Unclip the sides: 3 단계, 이미지 2개 중 1개 Dell Inspiron 3501 Back Cover Replacement, Unclip the sides: 3 단계, 이미지 2개 중 2개
    • At the sides of the laptop, insert your opening pick between the cover and body.
    • Pry upward to release the remainder of the clips.
  4. Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Dell Inspiron 3501 Back Cover Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Grab the cover by the edge closest to you.
    • Lift the cover up. Swing it open so that the rear edge lifts up last.
    • Completely remove the cover from the laptop.
    • If the back cover is stuck to laptop body, use an opening pick to slide around the perimeter of the back cover to release any remaining clips.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell Inspiron answers community for help.
Clay Eickemeyer
회원 가입일: 09/19/22
96,090 평판
안내서 466개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 71
전체 시간: 2,175
