주요 콘텐츠로 건너뛰기
Dell Inspiron 3501 SSD Replacement
필요한 것
  1. Dell Inspiron 3501 SSD Replacement, Unfasten the back cover: 1 단계, 이미지 2개 중 1개 Dell Inspiron 3501 SSD Replacement, Unfasten the back cover: 1 단계, 이미지 2개 중 2개
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use the Phillips screwdriver to remove the seven 6 mm-long screws securing the back cover.
    • Use the Phillips screwdriver to loosen the two captive screws.
  2. Dell Inspiron 3501 SSD Replacement, Unclip the front corners: 2 단계, 이미지 2개 중 1개 Dell Inspiron 3501 SSD Replacement, Unclip the front corners: 2 단계, 이미지 2개 중 2개
    • Insert an opening pick between the bottom-left corner of the back cover and the laptop body.
    • Pry upward to release the retaining clips.
    • Listen for a click sound when each clip releases.
    • Repeat this procedure for the bottom-right corner of the back cover.
  3. Dell Inspiron 3501 SSD Replacement, Unclip the sides: 3 단계, 이미지 2개 중 1개 Dell Inspiron 3501 SSD Replacement, Unclip the sides: 3 단계, 이미지 2개 중 2개
    • At the sides of the laptop, insert your opening pick between the cover and body.
    • Pry upward to release the remainder of the clips.
  4. Dell Inspiron 3501 SSD Replacement, Remove the back cover: 4 단계, 이미지 3개 중 1개 Dell Inspiron 3501 SSD Replacement, Remove the back cover: 4 단계, 이미지 3개 중 2개 Dell Inspiron 3501 SSD Replacement, Remove the back cover: 4 단계, 이미지 3개 중 3개
    • Grab the cover by the edge closest to you.
    • Lift the cover up. Swing it open so that the rear edge lifts up last.
    • Completely remove the cover from the laptop.
    • If the back cover is stuck to laptop body, use an opening pick to slide around the perimeter of the back cover to release any remaining clips.
  5. Dell Inspiron 3501 SSD Replacement, Disconnect the battery: 5 단계, 이미지 2개 중 1개 Dell Inspiron 3501 SSD Replacement, Disconnect the battery: 5 단계, 이미지 2개 중 2개
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 SSD Replacement, Unfasten the SSD cover: 6 단계, 이미지 2개 중 1개 Dell Inspiron 3501 SSD Replacement, Unfasten the SSD cover: 6 단계, 이미지 2개 중 2개
    • Use your Phillips screwdriver to remove the 4 mm-long screw securing the silver SSD shield.
    • Use your Phillips screwdriver to loosen the captive screw.
  7. Dell Inspiron 3501 SSD Replacement, Remove the SSD cover: 7 단계, 이미지 2개 중 1개 Dell Inspiron 3501 SSD Replacement, Remove the SSD cover: 7 단계, 이미지 2개 중 2개
    • Lift the SSD cover straight off the SSD to remove it.
  8. Dell Inspiron 3501 SSD Replacement, Remove the SSD: 8 단계, 이미지 3개 중 1개 Dell Inspiron 3501 SSD Replacement, Remove the SSD: 8 단계, 이미지 3개 중 2개 Dell Inspiron 3501 SSD Replacement, Remove the SSD: 8 단계, 이미지 3개 중 3개
    • Grip the edges of the SSD near the screw indent.
    • Pull the SSD straight out from its socket and remove it.
    • If it feels stuck, gently wiggle it side to side as you pull.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell Inspiron answers community for help.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
96,048 평판
안내서 466개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 61
전체 시간: 2,125
