주요 콘텐츠로 건너뛰기
Dell Inspiron 3520 Keyboard Replacement
필요한 것
  1. Dell Inspiron 3520 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 3520 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Keyboard Replacement: 2 단계, 이미지 1/3 Dell Inspiron 3520 Keyboard Replacement: 2 단계, 이미지 2/3 Dell Inspiron 3520 Keyboard Replacement: 2 단계, 이미지 3/3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Dell Inspiron 3520 Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Keyboard Replacement: 4 단계, 이미지 1/1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Keyboard Replacement: 5 단계, 이미지 1/2 Dell Inspiron 3520 Keyboard Replacement: 5 단계, 이미지 2/2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Ian
회원 가입일: 01/30/15
1,557 평판
안내서 5개 작성하였습니다
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 회원
USFT-WATKINS-W15S16G2
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Hi, any ideas why a NEW keyboard still wouldn't work after installing it? The ribbon was connected properly, it’s the right keyboard, and I made sure the driver was updated. Any help would be greatly appreciated. Started a new job and my keyboard went to $@$* in the first week. Can’t really afford to buy a new laptop this weekend. It works with an external USB keyboard so it’s probably not a software issue… I think?
Alittle advice would be greatly appreciated. Thanks!
Stumpedu - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 38
전체 시간: 6,021
