소개
This repair process involves going into the computer, therefore,you will need to be gentle with electronic components. Also, consider working on this repair in a clean environment so no small pieces of the computer are lost.
필요한 것
Turn off notebook
Set the notebook upside down with the battery facing away from you.
Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
Locate the four tabs along the top edge of the keyboard.
Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
다른 17명이 해당 안내서를 완성하였습니다.
