주요 콘텐츠로 건너뛰기
Dell Inspiron 3542 Heat Sink Replacement
필요한 것
  1. Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: 1 단계, 이미지 1/2 Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: 1 단계, 이미지 2/2
    • Slide the latches on both sides of the computer outward to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Inspiron 3542 Heat Sink Replacement: 2 단계, 이미지 1/2 Dell Inspiron 3542 Heat Sink Replacement: 2 단계, 이미지 2/2
    • Remove the screw. (1x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inspiron 3542 Heat Sink Replacement: 3 단계, 이미지 1/3 Dell Inspiron 3542 Heat Sink Replacement: 3 단계, 이미지 2/3 Dell Inspiron 3542 Heat Sink Replacement: 3 단계, 이미지 3/3
    • Remove the screw. (1 x m2 x 3mm)
    • Move the hard drive to the open area and remove it.
  4. Dell Inspiron 3542 Heat Sink Replacement: 4 단계, 이미지 1/3 Dell Inspiron 3542 Heat Sink Replacement: 4 단계, 이미지 2/3 Dell Inspiron 3542 Heat Sink Replacement: 4 단계, 이미지 3/3
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the screw. (1 x M2 x 3mm)
    • Remove the wireless card from the laptop.
  5. Dell Inspiron 3542 Heat Sink Replacement: 5 단계, 이미지 1/3 Dell Inspiron 3542 Heat Sink Replacement: 5 단계, 이미지 2/3 Dell Inspiron 3542 Heat Sink Replacement: 5 단계, 이미지 3/3
    • Turn over the laptop and open it.
    • Use the plastic prying device to release the keyboard.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
    • Remove the screws. (3 x M2.5 x 5mm)
  6. Dell Inspiron 3542 Heat Sink Replacement: 6 단계, 이미지 1/2 Dell Inspiron 3542 Heat Sink Replacement: 6 단계, 이미지 2/2
    • Unplug the touch pad cables located on the palm rest.
  7. Dell Inspiron 3542 Heat Sink Replacement: 7 단계, 이미지 1/3 Dell Inspiron 3542 Heat Sink Replacement: 7 단계, 이미지 2/3 Dell Inspiron 3542 Heat Sink Replacement: 7 단계, 이미지 3/3
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  8. Dell Inspiron 3542 Heat Sink Replacement: 8 단계, 이미지 1/1
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  9. Dell Inspiron 3542 Heat Sink Replacement: 9 단계, 이미지 1/1
    • Loosen the cables on the antenna.
  10. Dell Inspiron 3542 Heat Sink Replacement: 10 단계, 이미지 1/1
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  11. Dell Inspiron 3542 Heat Sink Replacement: 11 단계, 이미지 1/2 Dell Inspiron 3542 Heat Sink Replacement: 11 단계, 이미지 2/2
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  12. Dell Inspiron 3542 Heat Sink Replacement: 12 단계, 이미지 1/3 Dell Inspiron 3542 Heat Sink Replacement: 12 단계, 이미지 2/3 Dell Inspiron 3542 Heat Sink Replacement: 12 단계, 이미지 3/3
    • Unplug the cable on the bottom part of the mother board.
    • Remove the motherboard from the laptop.
  13. Dell Inspiron 3542 Heat Sink Replacement: 13 단계, 이미지 1/3 Dell Inspiron 3542 Heat Sink Replacement: 13 단계, 이미지 2/3 Dell Inspiron 3542 Heat Sink Replacement: 13 단계, 이미지 3/3
    • Turn over the motherboard.
    • Unplug the cooling fan.
    • Loosen the 3 screws from the heat sink.
    • Remove the heat sink.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Rachel lindsey
회원 가입일: 03/21/17
718 평판
안내서 5개 작성하였습니다
Texas Tech, Team S46-G1, Bennett Spring 2017 Texas Tech, Team S46-G1, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 15
전체 시간: 1,366
