주요 콘텐츠로 건너뛰기
Dell Inspiron 3552 Memory Module Replacement
필요한 것
  1. Dell Inspiron 3552 Memory Module  Replacement, Removing the battery: 1 단계, 이미지 1/1
    • Close the display and turn the computer over
    • Slide the battery-release latch to the unlocked position
    • Lift the battery at an angle and remove the battery from the battery bay.
    • Turn the computer over, open the display, and press the power button for five seconds to ground the system board
  2. Dell Inspiron 3552 Memory Module  Replacement, removing memory module: 2 단계, 이미지 1/1
    • Using your fingertips, spread apart the securing clips at each end of the memory-module slot until the memory module pops up.
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 3552 Memory Module  Replacement, Replacing Ram: 3 단계, 이미지 1/1
    • Align the notch on the memory module with the tab on the memory-module slot.
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordon Dozier
회원 가입일: 02/10/21
1,588 평판
안내서 12개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,989개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 32
