주요 콘텐츠로 건너뛰기
Dell Inspiron 3847 RAM Stick Replacement
필요한 것
  1. Dell Inspiron 3847 RAM Stick Replacement, RAM Stick: 1 단계, 이미지 1개 중 1개
    • Shut off and power down the PC by turning the switch to the off position, located on the back of the PC.
    • Unplug the power cable and remove any and all peripherals connected to PC.
  2. Dell Inspiron 3847 RAM Stick Replacement: 2 단계, 이미지 3개 중 1개 Dell Inspiron 3847 RAM Stick Replacement: 2 단계, 이미지 3개 중 2개 Dell Inspiron 3847 RAM Stick Replacement: 2 단계, 이미지 3개 중 3개
    • Lay your PC flat on its side with the 'Inspiron' Logo facing up.
    • Remove the two Phillips #0 screws from the back side of panel.
    • Slide the side panel off completely.
  3. Dell Inspiron 3847 RAM Stick Replacement: 3 단계, 이미지 2개 중 1개 Dell Inspiron 3847 RAM Stick Replacement: 3 단계, 이미지 2개 중 2개
    • Gently press down the flaps located on each end of the RAM slots. Remove the RAM stick(s) from the motherboard.
    • Repeat this step for each stick of RAM.
    • The flaps may be stiff when pressing down. Be careful not to use too much force if the RAM stick doesn't come loose.
  4. Dell Inspiron 3847 RAM Stick Replacement: 4 단계, 이미지 3개 중 1개 Dell Inspiron 3847 RAM Stick Replacement: 4 단계, 이미지 3개 중 2개 Dell Inspiron 3847 RAM Stick Replacement: 4 단계, 이미지 3개 중 3개
    • Align the new memory sticks with the memory slots.
    • Gently press down until a “CLICK” sound is made and flaps are pointing upwards.
    • Repeat this step for each stick of RAM you want to install.
  5. Dell Inspiron 3847 RAM Stick Replacement: 5 단계, 이미지 3개 중 1개 Dell Inspiron 3847 RAM Stick Replacement: 5 단계, 이미지 3개 중 2개 Dell Inspiron 3847 RAM Stick Replacement: 5 단계, 이미지 3개 중 3개
    • Slide the side panel back into position and screw in with the same screws from Step #2.
    • Plug all peripherals into the PC and switch it back on.
    • Boot up the computer. If no errors appear, then installation is complete!
결론
To check if your RAM is installed correctly, Right-click on My PC, Click Properties, and check Installed Memory under the System heading.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Maninder
회원 가입일: 05/11/20
195 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 41
전체 시간: 1,357
