주요 콘텐츠로 건너뛰기
Dell Inspiron 5100 (2015) Thermal Paste Replacement
필요한 것
  1. Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: 1 단계, 이미지 1/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: 1 단계, 이미지 2/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: 1 단계, 이미지 3/3
    • Use the slider to release and remove the battery.
    • Remove the 11 screws using a small tip Phillips screwdriver.
  2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 2 단계, 이미지 1/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 2 단계, 이미지 2/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 2 단계, 이미지 3/3
    • Use a flat screw driver to pry against the angled metal.
    • Remove the 3 small screws that were under the optical drive using a small tip Phillips screwdriver.
  3. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 3 단계, 이미지 1/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 3 단계, 이미지 2/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 3 단계, 이미지 3/3
    • Use a small flat-head screwdriver to pry up at each point indicated to unclip the keyboard from the chassis.
    • Lift the keyboard 2-3 inches up and carefully disconnect the two ribbon cables by unlatching the mechanism and carefully sliding the cable out horizontally.
    • Place the keyboard to the side.
  4. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 4 단계, 이미지 1/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 4 단계, 이미지 2/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 4 단계, 이미지 3/3
    • Remove the 5 screws using the small Phillips screwdriver.
  5. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 5 단계, 이미지 1/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 5 단계, 이미지 2/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 5 단계, 이미지 3/3
    • Grab the bottom panel where the optical drive was and lift straight up.
    • It should start popping clips and then come off without much force required.
    • Pay special attention to not break any plastic clips.
  6. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 6 단계, 이미지 1/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 6 단계, 이미지 2/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 6 단계, 이미지 3/3
    • Loosen the screws one at a time and repeat until they are fully unscrewed.
    • Unplug the fan cable from the header by sliding it out horizontally.
    • Lift the cooler off the CPU with one hand on the CPU area and one hand on the fan assembly.
  7. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 7 단계, 이미지 1/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 7 단계, 이미지 2/3 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 7 단계, 이미지 3/3
    • Using paper towels, q-tips, and isopropyl alcohol, clean off the old thermal paste on the CPU and heatsink.
    • Be careful around the CPU; it is delicate and can be damaged.
  8. Dell Inspiron 5100 (2015) Thermal Paste Replacement: 8 단계, 이미지 1/2 Dell Inspiron 5100 (2015) Thermal Paste Replacement: 8 단계, 이미지 2/2
    • Apply a grain of rice amount of thermal paste to the CPU in the indicated spots.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dominic Treadwell
회원 가입일: 07/09/23
184 평판
안내서 1개 작성함
Austin Community College, Team 1-8, Meigs Summer 2023 Austin Community College, Team 1-8, Meigs Summer 2023 회원
AUSTINCC-MEIGS-SU23S1G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 26
전체 시간: 205
