주요 콘텐츠로 건너뛰기
Dell Inspiron 5100 PP07L CD Drive Replacement
필요한 것
  1. Dell Inspiron 5100 PP07L CD Drive Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove battery
    • Open screen so that it lies flat.
  2. Dell Inspiron 5100 PP07L CD Drive Replacement: 2 단계, 이미지 1/2 Dell Inspiron 5100 PP07L CD Drive Replacement: 2 단계, 이미지 2/2
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
  3. Dell Inspiron 5100 PP07L CD Drive Replacement: 3 단계, 이미지 1/2 Dell Inspiron 5100 PP07L CD Drive Replacement: 3 단계, 이미지 2/2
    • Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
  4. Dell Inspiron 5100 PP07L CD Drive Replacement: 4 단계, 이미지 1/1
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
  5. Dell Inspiron 5100 PP07L CD Drive Replacement, Screen: 5 단계, 이미지 1/2 Dell Inspiron 5100 PP07L CD Drive Replacement, Screen: 5 단계, 이미지 2/2
    • Using a Phillips screwdriver remove the two screws (5.8mm) located at the rear of the laptop.
  6. Dell Inspiron 5100 PP07L CD Drive Replacement: 6 단계, 이미지 1/1
    • Detach the screen connector.
  7. Dell Inspiron 5100 PP07L CD Drive Replacement: 7 단계, 이미지 1/2 Dell Inspiron 5100 PP07L CD Drive Replacement: 7 단계, 이미지 2/2
    • Using a Phillips screwdriver remove the four screws (5.8 mm) located at hinges of the screen.
  8. Dell Inspiron 5100 PP07L CD Drive Replacement: 8 단계, 이미지 1/1
    • Lift and remove display screen.
  9. Dell Inspiron 5100 PP07L CD Drive Replacement, CD Drive: 9 단계, 이미지 1/2 Dell Inspiron 5100 PP07L CD Drive Replacement, CD Drive: 9 단계, 이미지 2/2
    • Flip to the back side of the laptop.
    • Remove thirteen screws (8.6mm).
    • If battery has not yet been removed, remove it now and remove single silver-colored screw at top of empty battery bay.
  10. Dell Inspiron 5100 PP07L CD Drive Replacement: 10 단계, 이미지 1/2 Dell Inspiron 5100 PP07L CD Drive Replacement: 10 단계, 이미지 2/2
    • Remove one screw (8.6 mm) on metal plating.
    • Remove the metal plating.
  11. Dell Inspiron 5100 PP07L CD Drive Replacement: 11 단계, 이미지 1/1
    • Remove two screws (5.8mm)
  12. Dell Inspiron 5100 PP07L CD Drive Replacement: 12 단계, 이미지 1/2 Dell Inspiron 5100 PP07L CD Drive Replacement: 12 단계, 이미지 2/2
    • Disconnect cable.
  13. Dell Inspiron 5100 PP07L CD Drive Replacement: 13 단계, 이미지 1/2 Dell Inspiron 5100 PP07L CD Drive Replacement: 13 단계, 이미지 2/2
    • Make sure that single silver-colored screw has been removed from empty battery bay
    • Remove top cover by lifting the edges upward.
  14. Dell Inspiron 5100 PP07L CD Drive Replacement: 14 단계, 이미지 1/2 Dell Inspiron 5100 PP07L CD Drive Replacement: 14 단계, 이미지 2/2
    • Remove CD drive plating screw (5.8mm)
  15. Dell Inspiron 5100 PP07L CD Drive Replacement: 15 단계, 이미지 1/1
    • Slide outwards to remove
결론
다른 한 분이 해당 안내서를 완성하였습니다.
May Chauvin
회원 가입일: 04/14/11
201 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-34, Maness Spring 2011 Cal Poly, Team 12-34, Maness Spring 2011 회원
CPSU-MANESS-S11S12G34
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 4,429
