주요 콘텐츠로 건너뛰기
Dell Inspiron 5100 PP07L Heatsink Replacement
필요한 것
  1. Dell Inspiron 5100 PP07L Heatsink Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove battery
    • Open screen so that it lies flat.
  2. Dell Inspiron 5100 PP07L Heatsink Replacement: 2 단계, 이미지 1/2 Dell Inspiron 5100 PP07L Heatsink Replacement: 2 단계, 이미지 2/2
    • Starting from the right side of the hinge cover, use the flat end of the spudger to pry up the hinge cover and gently remove it.
  3. Dell Inspiron 5100 PP07L Heatsink Replacement: 3 단계, 이미지 1/2 Dell Inspiron 5100 PP07L Heatsink Replacement: 3 단계, 이미지 2/2
    • Using a Phillips screwdriver remove the four M2 x 3-mm screws holding in the keyboard.
  4. Dell Inspiron 5100 PP07L Heatsink Replacement: 4 단계, 이미지 1/1
    • Lift keyboard and detach the interface connector.
    • Take extra care when removing and handling the keyboard. The key caps on the keyboard are fragile and easily come off.
  5. Dell Inspiron 5100 PP07L Heatsink Replacement, Heatsink: 5 단계, 이미지 1/2 Dell Inspiron 5100 PP07L Heatsink Replacement, Heatsink: 5 단계, 이미지 2/2
    • Detach screen connector
  6. Dell Inspiron 5100 PP07L Heatsink Replacement: 6 단계, 이미지 1/2 Dell Inspiron 5100 PP07L Heatsink Replacement: 6 단계, 이미지 2/2
    • Remove two screws (5.8mm) located behind the screen.
  7. Dell Inspiron 5100 PP07L Heatsink Replacement: 7 단계, 이미지 1/2 Dell Inspiron 5100 PP07L Heatsink Replacement: 7 단계, 이미지 2/2
    • Remove one screw (8.6 mm) on metal plating.
    • Remove the metal plating
  8. Dell Inspiron 5100 PP07L Heatsink Replacement: 8 단계, 이미지 1/2 Dell Inspiron 5100 PP07L Heatsink Replacement: 8 단계, 이미지 2/2
    • Loosen four screws.
    • These screws are attached to the heat sink and cannot be completely removed.
  9. Dell Inspiron 5100 PP07L Heatsink Replacement: 9 단계, 이미지 1/2 Dell Inspiron 5100 PP07L Heatsink Replacement: 9 단계, 이미지 2/2
    • Disconnect the wire connecting the heatsink to the motherboard.
  10. Dell Inspiron 5100 PP07L Heatsink Replacement: 10 단계, 이미지 1/1
    • Slide the heatsink away from the screen and lift.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
May Chauvin
회원 가입일: 04/14/11
201 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-34, Maness Spring 2011 Cal Poly, Team 12-34, Maness Spring 2011 회원
CPSU-MANESS-S11S12G34
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 3,817
