소개
This guide will provide you with a step-by-step procedure of how to remove the keyboard on your Dell Inspiron 5100 PP07L. Be advised: this guide will require you to remove your laptop battery. Use caution when removing the battery, as lithium ion batteries (like the one in this laptop) can be dangerous if handled incorrectly. Be sure to carefully follow the instructions of this guide to avoid breaking the hinge cover of your laptop and to prevent key caps from being broken.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
