주요 콘텐츠로 건너뛰기
Dell Inspiron 5100 PP07L Memory Replacement
필요한 것
  1. Dell Inspiron 5100 PP07L Memory Replacement, Revealing the memory panel: 1 단계, 이미지 1/1
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. Dell Inspiron 5100 PP07L Memory Replacement, Screw Removal: 2 단계, 이미지 1/1
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  3. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: 3 단계, 이미지 1/3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: 3 단계, 이미지 2/3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: 3 단계, 이미지 3/3
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
결론
다른 2명이 해당 안내서를 완성하였습니다.
May Chauvin
회원 가입일: 04/14/11
201 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-34, Maness Spring 2011 Cal Poly, Team 12-34, Maness Spring 2011 회원
CPSU-MANESS-S11S12G34
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 4,519
