주요 콘텐츠로 건너뛰기
Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement
필요한 것
  1. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement, PCI Slot: Dial up modem: 1 단계, 이미지 1/2 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement, PCI Slot: Dial up modem: 1 단계, 이미지 2/2
    • Unscrew the two large screws in the back holding on the side panel.
    • Slide the panel backwards to remove it.
  2. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: 2 단계, 이미지 1/3 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: 2 단계, 이미지 2/3 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: 2 단계, 이미지 3/3
    • The PCI slots are located at the bottom back of the computer.
    • Unscrew the screw to release the metal piece that holds the cards in place.
    • Remove metal piece.
  3. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: 3 단계, 이미지 1/2 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: 3 단계, 이미지 2/2
    • Slide the card in the PCI slot up and out.
    • In this case, it is a dial up modem.
  4. Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: 4 단계, 이미지 1/3 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: 4 단계, 이미지 2/3 Dell Inspiron 530 DCMF PCI Slot:Dial up modem Replacement: 4 단계, 이미지 3/3
    • Take the new card and slide it into the slot that you removed the old one out of.
    • Remember to replace the metal piece you removed earlier to secure the cards in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Drew Cunningham
회원 가입일: 03/25/15
656 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-1, Kish Spring 2015 UMass Dartmouth, Team 5-1, Kish Spring 2015 회원
UMASSD-KISH-S15S5G1
5 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 830
