주요 콘텐츠로 건너뛰기
Dell Inspiron 5555 Motherboard Replacement
필요한 것
  1. Dell Inspiron 5555 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Close the laptop and lay it flat, logo side down.
    • Make sure that the battery is visible and at the top of the device.
  2. Dell Inspiron 5555 Motherboard Replacement: 2 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 2 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 2 단계, 이미지 3/3
    • Push the lock switch to the left to pop out the battery.
  3. Dell Inspiron 5555 Motherboard Replacement: 3 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 3 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 3 단계, 이미지 3/3
    • When the battery pops out, lift it so that it comes out completely.
  4. Dell Inspiron 5555 Motherboard Replacement, Keyboard: 4 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement, Keyboard: 4 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement, Keyboard: 4 단계, 이미지 3/3
    • Turn the laptop over and open the device.
    • Insert the flat end of the spudger into the five notches located at the top of the keyboard and pry the keyboard up by pushing down and up.
  5. Dell Inspiron 5555 Motherboard Replacement: 5 단계, 이미지 1/2 Dell Inspiron 5555 Motherboard Replacement: 5 단계, 이미지 2/2
    • Lift up and slide back to release the six notches from the bottom of the keyboard.
    • Be careful not to lift the keyboard up all the way because it is still connected to the laptop by a cable on the bottom.
  6. Dell Inspiron 5555 Motherboard Replacement: 6 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 6 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 6 단계, 이미지 3/3
    • Flip the keyboard upside down to access the keyboard cable.
    • Using the flat end of the spudger, flip the black tab securing the keyboard cable up to remove the keyboard cable.
    • Remove the keyboard by lifting it off of the laptop.
  7. Dell Inspiron 5555 Motherboard Replacement, Fan: 7 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement, Fan: 7 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement, Fan: 7 단계, 이미지 3/3
    • Remove the six 5 mm screws using the Phillips #0 screwdriver.
    • Use the spudger to lift the black tab of the ZIF connector, removing the optical drive cable.
  8. Dell Inspiron 5555 Motherboard Replacement: 8 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 8 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    구매
    • Using the hooked end of the Halberd Spudger, pull the black tab to the left to expose the touchpad cable.
    • Close the laptop and flip it over, so the bottom is facing up.
  9. Dell Inspiron 5555 Motherboard Replacement: 9 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 9 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove the 5 mm screw using the Phillips #0 Screwdriver.
    • Use the flat end of the spudger to slide the optical drive out to the left at the screwdriver push point.
  10. Dell Inspiron 5555 Motherboard Replacement: 10 단계, 이미지 1/2 Dell Inspiron 5555 Motherboard Replacement: 10 단계, 이미지 2/2
    • Pull the optical drive horizontally to the left to remove it from the laptop.
  11. Dell Inspiron 5555 Motherboard Replacement: 11 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 11 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 11 단계, 이미지 3/3
    • Remove the two 8 mm screws with the Phillips #0 Screwdriver.
    • Use the iFixit opening tool to pry open the access door by pushing down and up at the notch on the top of the access door, running it along the edges.
  12. Dell Inspiron 5555 Motherboard Replacement: 12 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 12 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 12 단계, 이미지 3/3
    • Use the flat end of the spudger to lift the white tab up that holds the hard drive cable in place.
    • Remove the four 8 mm screws with the Phillips #0 screwdriver.
    • Lift the hard drive from the laptop.
  13. Dell Inspiron 5555 Motherboard Replacement: 13 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 13 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 13 단계, 이미지 3/3
    • Remove the 3 mm screw on the wireless card with a Phillips #0 screwdriver.
    • Lift the metal bracket to remove.
    • Detach the antenna cables at the gold metal end by carefully pulling them up from the Wireless WLAN Card.
    • Lift the Wireless WLAN Card from the device.
  14. Dell Inspiron 5555 Motherboard Replacement: 14 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 14 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 14 단계, 이미지 3/3
    • Remove the three 2 mm wafer screws in the optical drive port with the Phillips #0 screwdriver.
    • Remove the two 8 mm hinge screws with the Phillips #0 screwdriver.
    • Remove the three 5 mm screws from the battery opening with the Phillips #0 screwdriver.
    • Remove the 5 mm screw with the Phillips #0 screwdriver.
  15. Dell Inspiron 5555 Motherboard Replacement: 15 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 15 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 15 단계, 이미지 3/3
    • Remove the six 8 mm screws under the access door using the Phillips #0 Screwdriver.
    • Disconnect the speaker connection by using your fingers and carefully pulling it to the right.
    • It may be snug in the connector, so gradually use more force until the speaker connection disconnects.
  16. Dell Inspiron 5555 Motherboard Replacement: 16 단계, 이미지 1/2 Dell Inspiron 5555 Motherboard Replacement: 16 단계, 이미지 2/2
    • Using the flat end of the spudger, pry the bottom base off of the laptop by the crack around the perimeter of the laptop and running the spudger around the edges.
  17. Dell Inspiron 5555 Motherboard Replacement: 17 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 17 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 17 단계, 이미지 3/3
    • Using your fingers gently pull the fan cable out if its port.
    • Avoid pulling the fan cable out by the actual wire. Instead pull on the plastic white piece that is attached to the wire.
  18. Dell Inspiron 5555 Motherboard Replacement: 18 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 18 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 18 단계, 이미지 3/3
    • Loosen the three captive screws attached to the metal bracket of the fan using the Phillips #0 Screwdriver.
    • The screws should remain attached to the metal bracket by springs.
    • Carefully lift the fan out of the laptop.
  19. Dell Inspiron 5555 Motherboard Replacement, Motherboard: 19 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement, Motherboard: 19 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement, Motherboard: 19 단계, 이미지 3/3
    • Remove the 5 mm screw from the circuit board using the Phillips #0 screwdriver.
    • Loosen the circuit by lifting it up from the device.
    • The white and green cable will remain attached to the circuit board on the left end and attached to the motherboard on the right end.
  20. Dell Inspiron 5555 Motherboard Replacement: 20 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 20 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 20 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Halberd Spudger
    $2.99
    구매
    • Using the halberd spudger, pull back and up to lift the black tab that holds the LCD cable in place.
    • Pull the LCD cable out with your fingers.
  21. Dell Inspiron 5555 Motherboard Replacement: 21 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 21 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 21 단계, 이미지 3/3
    • Remove the 3 mm screw using the Phillips #0 screwdriver.
    • Carefully lift the motherboard and circuit board and turn it over.
    • The motherboard is still connected to the device so be careful to not yank up on it.
  22. Dell Inspiron 5555 Motherboard Replacement: 22 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 22 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 22 단계, 이미지 3/3
    • Using the flat end of the spudger, lift the white tab holding the USB circuit board cable attached to the motherboard to detach it from the motherboard.
  23. Dell Inspiron 5555 Motherboard Replacement: 23 단계, 이미지 1/3 Dell Inspiron 5555 Motherboard Replacement: 23 단계, 이미지 2/3 Dell Inspiron 5555 Motherboard Replacement: 23 단계, 이미지 3/3
    • Use your fingers to pull the DC jack cable out of its port, separating the motherboard from the rest of the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Marek Czyzycki Jr.
회원 가입일: 09/20/19
242 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 39
전체 시간: 1,654
