소개
This guide will show you how to replace the LCD Screen on the Dell Inspiron 5758.
Prerequisite guides are:
- Battery
- Hard Drive
- DC Jack
- Keyboard
필요한 것
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
Once you have removed the LCD display assembly from the palmrest touchpad, use a spudger to unsnap the LCD bezel via the notches on the outside edge of the bezel .
When you have removed the LCD bezel, place it to the side.
다른 2명이 해당 안내서를 완성하였습니다.
