주요 콘텐츠로 건너뛰기
Dell Inspiron 5758 Touchpad Replacement
필요한 것
  1. Dell Inspiron 5758 Touchpad Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 Touchpad Replacement: 2 단계, 이미지 1/3 Dell Inspiron 5758 Touchpad Replacement: 2 단계, 이미지 2/3 Dell Inspiron 5758 Touchpad Replacement: 2 단계, 이미지 3/3
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 Touchpad Replacement, DC Jack: 3 단계, 이미지 1/3 Dell Inspiron 5758 Touchpad Replacement, DC Jack: 3 단계, 이미지 2/3 Dell Inspiron 5758 Touchpad Replacement, DC Jack: 3 단계, 이미지 3/3
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 Touchpad Replacement: 4 단계, 이미지 1/1
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 Touchpad Replacement: 5 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement: 5 단계, 이미지 2/2
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 Touchpad Replacement: 6 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement: 6 단계, 이미지 2/2
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 Touchpad Replacement: 7 단계, 이미지 1/3 Dell Inspiron 5758 Touchpad Replacement: 7 단계, 이미지 2/3 Dell Inspiron 5758 Touchpad Replacement: 7 단계, 이미지 3/3
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 Touchpad Replacement: 8 단계, 이미지 1/1
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 Touchpad Replacement: 9 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement: 9 단계, 이미지 2/2
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 Touchpad Replacement: 10 단계, 이미지 1/1
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 Touchpad Replacement: 11 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement: 11 단계, 이미지 2/2
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 Touchpad Replacement: 12 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement: 12 단계, 이미지 2/2
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 Touchpad Replacement: 13 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement: 13 단계, 이미지 2/2
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 Touchpad Replacement: 14 단계, 이미지 1/3 Dell Inspiron 5758 Touchpad Replacement: 14 단계, 이미지 2/3 Dell Inspiron 5758 Touchpad Replacement: 14 단계, 이미지 3/3
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 Touchpad Replacement: 15 단계, 이미지 1/1
    • Remove the bottom base.
  16. Dell Inspiron 5758 Touchpad Replacement: 16 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement: 16 단계, 이미지 2/2
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 Touchpad Replacement: 17 단계, 이미지 1/3 Dell Inspiron 5758 Touchpad Replacement: 17 단계, 이미지 2/3 Dell Inspiron 5758 Touchpad Replacement: 17 단계, 이미지 3/3
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 Touchpad Replacement: 18 단계, 이미지 1/3 Dell Inspiron 5758 Touchpad Replacement: 18 단계, 이미지 2/3 Dell Inspiron 5758 Touchpad Replacement: 18 단계, 이미지 3/3
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
  19. Dell Inspiron 5758 Touchpad Replacement, Touchpad: 19 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement, Touchpad: 19 단계, 이미지 2/2
    • Release the antenna cable tape.
    • Release the antenna cables.
  20. Dell Inspiron 5758 Touchpad Replacement: 20 단계, 이미지 1/3 Dell Inspiron 5758 Touchpad Replacement: 20 단계, 이미지 2/3 Dell Inspiron 5758 Touchpad Replacement: 20 단계, 이미지 3/3
    • Remove the four 5mm right hinge screws using the Phillips #00 screwdriver.
    • Remove the three 5mm left hinge screws using Phillips #00 screwdriver.
    • Open the hinges carefully and remove the LCD display assembly.
  21. Dell Inspiron 5758 Touchpad Replacement: 21 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement: 21 단계, 이미지 2/2
    • Remove the one 2mm wafer screw using Phillips #0 screwdriver.
    • Loosen the cable and remove the power button circuit board.
  22. Dell Inspiron 5758 Touchpad Replacement: 22 단계, 이미지 1/2 Dell Inspiron 5758 Touchpad Replacement: 22 단계, 이미지 2/2
    • Push up on the touchpad to release it from the housing.
    • Remove the touchpad.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Majed
회원 가입일: 09/18/18
196 평판
안내서 1개 작성함
University of North Texas, Team S3-G4, Raign Fall 2018 University of North Texas, Team S3-G4, Raign Fall 2018 회원
UNT-RAIGN-F18S3G4
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 645
