소개
This guide will show you how to replace the touchpad on the Dell Inspiron 5758.
필요한 것
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
