주요 콘텐츠로 건너뛰기
Dell Inspiron 6000 DVD/CD Drive Replacement
필요한 것
  1. Dell Inspiron 6000 DVD/CD Drive Replacement, Battery: 1 단계, 이미지 1/1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 DVD/CD Drive Replacement: 2 단계, 이미지 1/1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 DVD/CD Drive Replacement, Removing the DVD/CD Drive Screw: 3 단계, 이미지 1/1
    • Remove one 4mm Philips #00 screw.
  4. Dell Inspiron 6000 DVD/CD Drive Replacement, Inserting Paper Clip: 4 단계, 이미지 1/1
    • Open the paperclip as seen here.
    • Insert the paper clip into small hole next to the eject button on the disk drive.
  5. Dell Inspiron 6000 DVD/CD Drive Replacement, Popping Out the DVD/CD Drive: 5 단계, 이미지 1/1
    • With slight pressure, push the paperclip into the laptop.
    • The disk drive will slowly "pop out" of the side of the laptop.
  6. Dell Inspiron 6000 DVD/CD Drive Replacement, Completely removing the DVD/CD Drive: 6 단계, 이미지 1/1
    • Using your hand, pull the disk drive out of the laptop.
결론
Kenneth Odum
회원 가입일: 09/23/14
545 평판
안내서 4개 작성하였습니다
USF Tampa, Team 11-1, Blackwell Fall 2014 USF Tampa, Team 11-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G1
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 1,880
