주요 콘텐츠로 건너뛰기
Dell Inspiron 6000 Screen Replacement
필요한 것
  1. Dell Inspiron 6000 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Screen Replacement: 2 단계, 이미지 1/1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Screen Replacement, Keyboard: 3 단계, 이미지 1/3 Dell Inspiron 6000 Screen Replacement, Keyboard: 3 단계, 이미지 2/3 Dell Inspiron 6000 Screen Replacement, Keyboard: 3 단계, 이미지 3/3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Screen Replacement: 4 단계, 이미지 1/2 Dell Inspiron 6000 Screen Replacement: 4 단계, 이미지 2/2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Screen Replacement: 5 단계, 이미지 1/1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Screen Replacement: 6 단계, 이미지 1/3 Dell Inspiron 6000 Screen Replacement: 6 단계, 이미지 2/3 Dell Inspiron 6000 Screen Replacement: 6 단계, 이미지 3/3
    • Gently pull the blue tab up until it comes away from computer.
  7. Dell Inspiron 6000 Screen Replacement, Screen: 7 단계, 이미지 1/1
    • Remove one 4mm Philips #00 screw to completely disengage blue tab.
  8. Dell Inspiron 6000 Screen Replacement: 8 단계, 이미지 1/1
    • Pull and disconnect the blue tab.
  9. Dell Inspiron 6000 Screen Replacement: 9 단계, 이미지 1/1
    • Disconnect the black and white wires.
  10. Dell Inspiron 6000 Screen Replacement: 10 단계, 이미지 1/1
    • Remove four 4mm Philips #00 screws at the hinges for the screen.
  11. Dell Inspiron 6000 Screen Replacement: 11 단계, 이미지 1/1
    • Separate the top panel of the laptop from the bottom panel.
  12. Dell Inspiron 6000 Screen Replacement: 12 단계, 이미지 1/2 Dell Inspiron 6000 Screen Replacement: 12 단계, 이미지 2/2
    • Use the plastic opening tools to remove the six rubber screw covers in the corners.
    • Remove six 4 mm #00 Philips screws located in the corners.
  13. Dell Inspiron 6000 Screen Replacement: 13 단계, 이미지 1/2 Dell Inspiron 6000 Screen Replacement: 13 단계, 이미지 2/2
    • Insert the plastic opening tools between the screen holders.
    • Go completely around the screen, separating the screen holders with the plastic opening tools.
  14. Dell Inspiron 6000 Screen Replacement: 14 단계, 이미지 1/2 Dell Inspiron 6000 Screen Replacement: 14 단계, 이미지 2/2
    • Remove 12 4mm #00 Philips screws at the perimeter of the screen.
  15. Dell Inspiron 6000 Screen Replacement: 15 단계, 이미지 1/2 Dell Inspiron 6000 Screen Replacement: 15 단계, 이미지 2/2
    • Gently lift the screen from the holder.
    • Do not touch the copper part of the bottom side of the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jacob DeWar
회원 가입일: 09/23/14
533 평판
안내서 3개 작성하였습니다
USF Tampa, Team 11-1, Blackwell Fall 2014 USF Tampa, Team 11-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G1
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 32
전체 시간: 2,620
