주요 콘텐츠로 건너뛰기
Dell Inspiron 600m Hard Drive Replacement
필요한 것
  1. Dell Inspiron 600m Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 Dell Inspiron 600m Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 Dell Inspiron 600m Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/1
    • The hard drive is located here.
  3. Dell Inspiron 600m Hard Drive Replacement: 3 단계, 이미지 1/1
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  4. Dell Inspiron 600m Hard Drive Replacement: 4 단계, 이미지 1/1
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Todd
회원 가입일: 04/05/11
146 평판
안내서 1개 작성함
Cal Poly, Team 10-40, Forte Spring 2011 Cal Poly, Team 10-40, Forte Spring 2011 회원
CPSU-FORTE-S11S10G40
5 회원들
안내서 8개 작성하였습니다
댓글 2개
What size is the hard drive, you know, to buy a new one?
Ethan White - 답글
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 33
전체 시간: 17,221
