소개
This guide is will show how to replace a faulty hard drive.
부품
No parts specified.
  1. Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily. Push in the tab on the battery and lift up. The battery should detach very easily.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. The hard drive is located here.
    • The hard drive is located here.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  5. Pull the hard drive tray directly away from the computer. The tray should slide out easily.
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Todd
회원 가입일: 2011년 04월 05일
86 평판
안내서 1개 작성함
Cal Poly, Team 10-40, Forte Spring 2011 Cal Poly, Team 10-40, Forte Spring 2011 회원
CPSU-FORTE-S11S10G40
5 회원들
안내서 8개 작성하였습니다
What size is the hard drive, you know, to buy a new one?
Ethan White - 답글
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 52
전체 시간: 14,067
