이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip laptop upside down and locate the battery as shown in the images.
Push in the tab on the battery and lift up. The battery should detach very easily.
Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
Pull the hard drive tray directly away from the computer. The tray should slide out easily.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 2개
What size is the hard drive, you know, to buy a new one?
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - 답글
