주요 콘텐츠로 건너뛰기
Dell Inspiron 6400 keyboard Replacement
필요한 것
  1. Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: 1 단계, 이미지 1/3 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: 1 단계, 이미지 2/3 Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: 1 단계, 이미지 3/3
    • Turn over laptop .Remove battery from laptop by pushing the two tabs are highlighted in blue. Place the battery off to the side.
  2. Dell Inspiron 6400 keyboard Replacement: 2 단계, 이미지 1/3 Dell Inspiron 6400 keyboard Replacement: 2 단계, 이미지 2/3 Dell Inspiron 6400 keyboard Replacement: 2 단계, 이미지 3/3
    • Remove the 3 screws highlighted in red that secure the keyboard to the case using the screwdriver with largest phillips head in the box. Make
  3. Dell Inspiron 6400 keyboard Replacement: 3 단계, 이미지 1/3 Dell Inspiron 6400 keyboard Replacement: 3 단계, 이미지 2/3 Dell Inspiron 6400 keyboard Replacement: 3 단계, 이미지 3/3
    • Turn the device right side up and open the device to view the keyboard.
    • Remove the keyboard away from the case ,using a plastic spudger if necessary.
    • The keyboard will still be attached to the motherboard by a ribbon cable.
  4. Dell Inspiron 6400 keyboard Replacement: 4 단계, 이미지 1/3 Dell Inspiron 6400 keyboard Replacement: 4 단계, 이미지 2/3 Dell Inspiron 6400 keyboard Replacement: 4 단계, 이미지 3/3
    • Replace the new keyboard with plastic spudger.
    • The keyboard will have to be attached to the motherboard by a ribbon cable.
    • Snapped the keyboard back in place.
  5. Dell Inspiron 6400 keyboard Replacement: 5 단계, 이미지 1/3 Dell Inspiron 6400 keyboard Replacement: 5 단계, 이미지 2/3 Dell Inspiron 6400 keyboard Replacement: 5 단계, 이미지 3/3
    • Flip over the laptop
    • Put the screws back in laptop
  6. Dell Inspiron 6400 keyboard Replacement: 6 단계, 이미지 1/2 Dell Inspiron 6400 keyboard Replacement: 6 단계, 이미지 2/2
    • Place the battery and lock it into place
결론
kempc8
회원 가입일: 11/22/13
899 평판
안내서 7개 작성하였습니다
K and K Fixit K and K Fixit 회원
Business
1 회원
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 928
