주요 콘텐츠로 건너뛰기
Dell Inspiron 700m Battery Replacement
필요한 것
    • CAUTION: Before performing these procedures, disconnect the modem from the telephone wall jack. If you remove the battery while the system is powered on and power cable is connected to an electrical outlet and then reinstall the battery and disconnect the power cable within one and a half seconds, the system may shut down.
    • NOTICE: Do not replace the battery with the computer in standby mode.
    • Ensure that the computer is turned off, set to the hibernate power management mode, or connected to an electrical outlet
    • Slide and hold the battery bay latch release on the bottom of the computer, and then remove the battery from the bay.
    • To install the battery, slide the battery into the bay until the latch release clicks, it can be slid in easiest by sliding and holding the latch release while inserting the battery.
결론
Good Job!
you replaced your laptop battery.
다른 3명이 해당 안내서를 완성하였습니다.
irlanda
회원 가입일: 11/30/17
11,336 평판
안내서 2개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,985개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 212
