필요한 것
Ensure that the computer is turned off, set to the hibernate power management mode, or connected to an electrical outlet
Slide and hold the battery bay latch release on the bottom of the computer, and then remove the battery from the bay.
To install the battery, slide the battery into the bay until the latch release clicks, it can be slid in easiest by sliding and holding the latch release while inserting the battery.
Good Job!
you replaced your laptop battery.
Good Job!
다른 3명이 해당 안내서를 완성하였습니다.
