주요 콘텐츠로 건너뛰기
Dell Inspiron 7568 Keyboard Replacement Guide
필요한 것
  1. Dell Inspiron 7568 Keyboard Replacement Guide, Battery: 1 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the ten 7mm Phillips #1 screws on the bottom cover.
    • Remove the bottom cover.
  2. Dell Inspiron 7568 Keyboard Replacement Guide: 2 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 2 단계, 이미지 2개 중 2개
    • Remove the four 3mm Phillips #1 screws holding the battery.
    • Unhinge the connector cable to the battery.
    • Remove the battery.
  3. Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: 3 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide, Display Assembly: 3 단계, 이미지 2개 중 2개
    • Unscrew & remove the two 3mm screws (using a ph1 screwdriver bit) and the cable bracket, above the motherboard
    • Doing this will allow one to access the LCD-motherboard connector cables.
  4. Dell Inspiron 7568 Keyboard Replacement Guide: 4 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 4 단계, 이미지 2개 중 2개
    • Unscrew the 7mm screws that secure the left and right hinges (using a ph1 screwdriver bit).
  5. Dell Inspiron 7568 Keyboard Replacement Guide: 5 단계, 이미지 3개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 5 단계, 이미지 3개 중 2개 Dell Inspiron 7568 Keyboard Replacement Guide: 5 단계, 이미지 3개 중 3개
    • Disconnect the antenna cable (under the left hinge)
    • Disconnect the LCD and Touchscreen display cables under the right hinge.
    • These are a set of two cables. For better image see image two in step one of this guide.
  6. Dell Inspiron 7568 Keyboard Replacement Guide: 6 단계, 이미지 1개 중 1개
    • Carefully separate the screen from the bottom half of the device.
  7. Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: 7 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide, Cooling Fan: 7 단계, 이미지 2개 중 2개
    • Begin by unclipping the cable connecting the fan and the motherboard.
    • Gently separate the motherboard cable from the clamp at the bottom of the fan.
    • Remove the cable.
  8. Dell Inspiron 7568 Keyboard Replacement Guide: 8 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 8 단계, 이미지 2개 중 2개
    • Remove the two 3mm Phillips #1 screws that hold the fan into place.
    • Remove the fan.
  9. Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: 9 단계, 이미지 3개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: 9 단계, 이미지 3개 중 2개 Dell Inspiron 7568 Keyboard Replacement Guide, Keyboard: 9 단계, 이미지 3개 중 3개
    • Once the battery, screen, cooling fan, trackpad are out, the device would resemble the one in the first picture of this step.
    • Unscrew the three screws connecting the copper pipe to the motherboard.
    • Remove the copper pipe.
  10. Dell Inspiron 7568 Keyboard Replacement Guide: 10 단계, 이미지 3개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 10 단계, 이미지 3개 중 2개 Dell Inspiron 7568 Keyboard Replacement Guide: 10 단계, 이미지 3개 중 3개
    • Unscrew the three 2mm wafer screws holding the motherboard.
    • Unplug the DC cable from the motherboard.
  11. Dell Inspiron 7568 Keyboard Replacement Guide: 11 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 11 단계, 이미지 2개 중 2개
    • Unplug the connecting strip
  12. Dell Inspiron 7568 Keyboard Replacement Guide: 12 단계, 이미지 3개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 12 단계, 이미지 3개 중 2개 Dell Inspiron 7568 Keyboard Replacement Guide: 12 단계, 이미지 3개 중 3개
    • Unplug the hard-drive cable
    • Remove the motherboard
  13. Dell Inspiron 7568 Keyboard Replacement Guide: 13 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 13 단계, 이미지 2개 중 2개
    • Unscrew the three 3mm screws holding the hard drive (using a ph1 screwdriver bit)
    • Remove the hard drive
  14. Dell Inspiron 7568 Keyboard Replacement Guide: 14 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 14 단계, 이미지 2개 중 2개
    • Unscrew the two 3mm screws holding the daughter board (using the ph1 screwdriver bit).
    • Set the daughterboard aside. NOTE: the daughter board doesn't have to be removed
  15. Dell Inspiron 7568 Keyboard Replacement Guide: 15 단계, 이미지 2개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 15 단계, 이미지 2개 중 2개
    • Unscrew & remove the twenty-eight 2mm bracket screws holding the keyboard bracket (using a PH000 screwdriver bit)
    • Remove the keyboard bracket
  16. Dell Inspiron 7568 Keyboard Replacement Guide: 16 단계, 이미지 1개 중 1개
    • Unscrew & remove the sixteen 2mm screws holding the keyboard (using a PH000 screwdriver bit)
  17. Dell Inspiron 7568 Keyboard Replacement Guide: 17 단계, 이미지 3개 중 1개 Dell Inspiron 7568 Keyboard Replacement Guide: 17 단계, 이미지 3개 중 2개 Dell Inspiron 7568 Keyboard Replacement Guide: 17 단계, 이미지 3개 중 3개
    • Unplug the keyboard ("KB") and backlight ("BL") cable
    • Remove the keyboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Luis Velez
회원 가입일: 02/19/17
452 평판
안내서 2개를 작성함
USF Tampa, Team S2-G2, Lacy Spring 2017 USF Tampa, Team S2-G2, Lacy Spring 2017 회원
USFT-LACY-S17S2G2
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 1,238
