주요 콘텐츠로 건너뛰기
Dell Inspiron 7573 2-in-1 Battery Replacement
필요한 것
  1. Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 7573 2-in-1 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Battery Replacement: 2 단계, 이미지 1/3 Dell Inspiron 7573 2-in-1 Battery Replacement: 2 단계, 이미지 2/3 Dell Inspiron 7573 2-in-1 Battery Replacement: 2 단계, 이미지 3/3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Battery Replacement: 4 단계, 이미지 1/3 Dell Inspiron 7573 2-in-1 Battery Replacement: 4 단계, 이미지 2/3 Dell Inspiron 7573 2-in-1 Battery Replacement: 4 단계, 이미지 3/3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kylie Freese
회원 가입일: 09/27/21
405 평판
안내서 3개 작성하였습니다
Casper College, Team 1-2, Lareau Fall 2021 Casper College, Team 1-2, Lareau Fall 2021 회원
CASC-LAREAU-F21S1G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 53
전체 시간: 2,378
