주요 콘텐츠로 건너뛰기
Dell Inspiron 7586 2-in-1 SSD Replacement
필요한 것
  1. Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: 1 단계, 이미지 1/3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: 1 단계, 이미지 2/3 Dell Inspiron 7586 2-in-1 SSD Replacement, SSD: 1 단계, 이미지 3/3
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #00 screwdriver to remove nine screws from the back case.
    • Insert an opening tool or spudger in the seam between the back case and the body of the laptop.
    • Work your way around the perimeter of the laptop and release the clips that secure the back case.
    • You will hear a clicking sound as the the clips are released and the back case is being removed.
    • Remove the back case.
  2. Dell Inspiron 7586 2-in-1 SSD Replacement: 2 단계, 이미지 1/3 Dell Inspiron 7586 2-in-1 SSD Replacement: 2 단계, 이미지 2/3 Dell Inspiron 7586 2-in-1 SSD Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the single screw securing the NVME drive.
    • Once the screw is removed, the SSD should pop up.
  3. Dell Inspiron 7586 2-in-1 SSD Replacement: 3 단계, 이미지 1/3 Dell Inspiron 7586 2-in-1 SSD Replacement: 3 단계, 이미지 2/3 Dell Inspiron 7586 2-in-1 SSD Replacement: 3 단계, 이미지 3/3
    • Gently slide the SSD out of the slot.
    • Make sure to gently pull out the drive to avoid damaging the M.2 slot where you insert the new SSD.
  4. Dell Inspiron 7586 2-in-1 SSD Replacement: 4 단계, 이미지 1/2 Dell Inspiron 7586 2-in-1 SSD Replacement: 4 단계, 이미지 2/2
    • Align the tooth edge of the SSD with the indents on the drive socket and gently insert the replacement SSD.
    • Press down on the SSD so the screw hole and drive align.
    • Use a Phillips #00 screwdriver to replace the screw.
    • Don't be scared to push down on the SSD as it should be level with the rest of the components.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mike03
회원 가입일: 03/05/24
139 평판
안내서 1개 작성함
CSU Los Angeles, Team 7-1, Grodsky Spring 2024 CSU Los Angeles, Team 7-1, Grodsky Spring 2024 회원
CSULA-GRODSKY-S24S7G1
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 70
