주요 콘텐츠로 건너뛰기
Dell Inspiron 7590 Battery Replacement
필요한 것
  1. Dell Inspiron 7590 Battery Replacement, Battery: 1 단계, 이미지 1/2 Dell Inspiron 7590 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove seven screws securing the base face of your device.
    • Unscrew the remaining two screws in the corners closest to the bottom of the base of the laptop.
  2. Dell Inspiron 7590 Battery Replacement: 2 단계, 이미지 1/3 Dell Inspiron 7590 Battery Replacement: 2 단계, 이미지 2/3 Dell Inspiron 7590 Battery Replacement: 2 단계, 이미지 3/3
    • Using a Jimmy, work your way around the edge of the back panel and the side of the laptop to remove the back panel.
    • Separate the remainder of the paneling using an Opening Pick.
    • Avoid using a metal utensil when separating the remainder of the paneling to avoid paint chipping.
  3. Dell Inspiron 7590 Battery Replacement: 3 단계, 이미지 1/3 Dell Inspiron 7590 Battery Replacement: 3 단계, 이미지 2/3 Dell Inspiron 7590 Battery Replacement: 3 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, remove the three screws securing the battery.
  4. Dell Inspiron 7590 Battery Replacement: 4 단계, 이미지 1/2 Dell Inspiron 7590 Battery Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, disconnect the ribbon cable connecting the battery to the motherboard.
  5. Dell Inspiron 7590 Battery Replacement: 5 단계, 이미지 1/2 Dell Inspiron 7590 Battery Replacement: 5 단계, 이미지 2/2
    • Remove the battery from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Danielle Byrd
회원 가입일: 02/13/20
145 평판
안내서 1개 작성함
댓글 한 개
Hello,
I noticed in your tear down there are two ram slots. I tried to find this information online, but was unable to. Are any of those ram slots an empty slot, to possibly upgrade?
Dave Szes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 18
전체 시간: 1,496
