소개
Follow this guide to remove the display module of your Dell Inspiron 8600.
도구
부품
지정된 부품이 없습니다.
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
다른 2명이 해당 안내서를 완성하였습니다.
