소개
We will show you how to remove both the upper and lower cases of the laptop. You will then remove the old strip then replace the hinge cover. And finally re-attach the upper and lower cases.
도구
부품
지정된 부품이 없습니다.
Remove the battery from the bottom of the laptop.
Please click on the following link for further instruction on how to remove the battery. Dell Inspiron 9100 Battery Replacement
Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
다른 한 분이 해당 안내서를 완성하였습니다.
