소개
If you need to replace the keyboard of your Dell Inspiron 8600, follow this guide.
도구
부품
지정된 부품이 없습니다.
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - 답글
