주요 콘텐츠로 건너뛰기
Dell Inspiron 8600 Keyboard Replacement
필요한 것
  1. Dell Inspiron 8600 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: 2 단계, 이미지 1/3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: 2 단계, 이미지 2/3 Dell Inspiron 8600 Keyboard Replacement, Hinge Cover: 2 단계, 이미지 3/3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Keyboard Replacement: 3 단계, 이미지 1/1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: 4 단계, 이미지 2/3 Dell Inspiron 8600 Keyboard Replacement, Keyboard: 4 단계, 이미지 3/3
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Perry
회원 가입일: 04/12/11
251 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 회원
CPSU-GARNER-S11S18G22
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 3,859
