이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If you are having difficulties with the keyboard, please follow this guide.
필요한 것
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Remove the screws at the top of the keyboard as indicated indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
The keyboard should be easily removable at this point.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
followed instructions, keyboard works great now!! All letters and numbers work! Thank you
fordsmtack - 답글
