주요 콘텐츠로 건너뛰기
Dell Inspiron 8600 LCD Replacement
필요한 것
  1. Dell Inspiron 8600 LCD Replacement, Hinge Cover: 1 단계, 이미지 1/3 Dell Inspiron 8600 LCD Replacement, Hinge Cover: 1 단계, 이미지 2/3 Dell Inspiron 8600 LCD Replacement, Hinge Cover: 1 단계, 이미지 3/3
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  2. Dell Inspiron 8600 LCD Replacement: 2 단계, 이미지 1/1
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  3. Dell Inspiron 8600 LCD Replacement, Display Module: 3 단계, 이미지 1/2 Dell Inspiron 8600 LCD Replacement, Display Module: 3 단계, 이미지 2/2
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  4. Dell Inspiron 8600 LCD Replacement: 4 단계, 이미지 1/1
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  5. Dell Inspiron 8600 LCD Replacement: 5 단계, 이미지 1/2 Dell Inspiron 8600 LCD Replacement: 5 단계, 이미지 2/2
    • Lift the display module directly upwards from the base of the computer.
  6. Dell Inspiron 8600 LCD Replacement: 6 단계, 이미지 1/1
    • Now remove the display module.
  7. Dell Inspiron 8600 LCD Replacement, LCD: 7 단계, 이미지 1/3 Dell Inspiron 8600 LCD Replacement, LCD: 7 단계, 이미지 2/3 Dell Inspiron 8600 LCD Replacement, LCD: 7 단계, 이미지 3/3
    • First, remove the plastic tabs that are covering the interior screws.
    • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
    • Note there are 8 tabs and 8 screws in total.
  8. Dell Inspiron 8600 LCD Replacement: 8 단계, 이미지 1/1
    • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
  9. Dell Inspiron 8600 LCD Replacement: 9 단계, 이미지 1/1
    • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
    • Note there are 8 screws in total for this step, 4 on each side of the unit.
  10. Dell Inspiron 8600 LCD Replacement: 10 단계, 이미지 1/1
    • Remove the broken LCD unit, and replace with new unit.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Perry
회원 가입일: 04/12/11
251 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 회원
CPSU-GARNER-S11S18G22
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
which controller board do i have to use for this model ?
bcdoor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 4,637
