주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Inspiron 8600 Lower Case Replacement
필요한 것
  1. Dell Inspiron 8600 Lower Case Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
    댓글 쓰기
  2. Dell Inspiron 8600 Lower Case Replacement, Hinge Cover: 2 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Lower Case Replacement, Hinge Cover: 2 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Lower Case Replacement, Hinge Cover: 2 단계, 이미지 3개 중 3개
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
    댓글 쓰기
  3. Dell Inspiron 8600 Lower Case Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
    댓글 쓰기
  4. Dell Inspiron 8600 Lower Case Replacement, Keyboard: 4 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Lower Case Replacement, Keyboard: 4 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Lower Case Replacement, Keyboard: 4 단계, 이미지 3개 중 3개
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
    댓글 쓰기
  5. Dell Inspiron 8600 Lower Case Replacement, Display Module: 5 단계, 이미지 2개 중 1개 Dell Inspiron 8600 Lower Case Replacement, Display Module: 5 단계, 이미지 2개 중 2개
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
    댓글 쓰기
  6. Dell Inspiron 8600 Lower Case Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
    댓글 쓰기
  7. Dell Inspiron 8600 Lower Case Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron 8600 Lower Case Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the display module directly upwards from the base of the computer.
    댓글 쓰기
  8. Dell Inspiron 8600 Lower Case Replacement: 8 단계, 이미지 1개 중 1개
    • Now remove the display module.
    댓글 쓰기
  9. Dell Inspiron 8600 Lower Case Replacement, Lower Case: 9 단계, 이미지 1개 중 1개
    • Remove the two screws holding down the upper case with a Phillips #1 screwdriver.
    댓글 쓰기
  10. Dell Inspiron 8600 Lower Case Replacement: 10 단계, 이미지 2개 중 1개 Dell Inspiron 8600 Lower Case Replacement: 10 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove four screws attaching the metal bar to the motherboard.
    • Remove the metal bar which connects the motherboard to the lower case.
    댓글 쓰기
  11. Dell Inspiron 8600 Lower Case Replacement: 11 단계, 이미지 1개 중 1개
    • Disconnect the optical disk drive by gently pulling upward on the plastic connector to prevent connection damage.
    댓글 쓰기
  12. Dell Inspiron 8600 Lower Case Replacement: 12 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Lower Case Replacement: 12 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Lower Case Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the optical disc drive by pushing a small release button on the side of the laptop and then pulling it.
    • This will uncover one final screw. Use the Phillips # 1 to remove the screw.
    댓글 쓰기
  13. Dell Inspiron 8600 Lower Case Replacement: 13 단계, 이미지 1개 중 1개
    • Now, pop off the lower case for repair or replacement.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
9다른 기여자 명과 함께
John Nesthus
회원 가입일: 04/13/11
186 평판
안내서 6개를 작성함
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 회원
CPSU-GARNER-S11S18G22
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 20
전체 시간: 4,000
