소개
Follow this guide to replace the top case of the Dell Inspiron 8600.
도구
부품
지정된 부품이 없습니다.
Locate the small opening at the upper left of the top blue panel which houses the power button.
Use a spudger to lift up and remove the blue panel.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
First, remove all tabs using a flat head/ finger.
Next, remove all screws using a #1 Philips screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
