주요 콘텐츠로 건너뛰기
Dell Inspiron 8600 Touch Pad Replacement
필요한 것
  1. Dell Inspiron 8600 Touch Pad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the battery from the bottom left of the laptop as shown.
    • Remove the battery before operating on the computer to avoid electrocution.
  2. Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: 2 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: 2 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Touch Pad Replacement, Hinge Cover: 2 단계, 이미지 3개 중 3개
    • Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
    • You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
    • Be careful of the wire attached to the underside of the hinge cover.
  3. Dell Inspiron 8600 Touch Pad Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the small black tab on the right hand side of the laptop.
    • You have now removed the hinge cover.
  4. Dell Inspiron 8600 Touch Pad Replacement, Keyboard: 4 단계, 이미지 3개 중 1개 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: 4 단계, 이미지 3개 중 2개 Dell Inspiron 8600 Touch Pad Replacement, Keyboard: 4 단계, 이미지 3개 중 3개
    • Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
    • Do not just lift up. There is a tab underneath the keyboard that is still connected to the mother board.
    • You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
    • The keyboard should be easily removable at this point.
  5. Dell Inspiron 8600 Touch Pad Replacement, Display Module: 5 단계, 이미지 2개 중 1개 Dell Inspiron 8600 Touch Pad Replacement, Display Module: 5 단계, 이미지 2개 중 2개
    • Flip the laptop over and remove the indicated screws.
    • Flip the laptop back over.
    • Find the two places where the display module is attached to the base of the computer.
  6. Dell Inspiron 8600 Touch Pad Replacement: 6 단계, 이미지 1개 중 1개
    • Disconnect the video card from the display module by gently lifting upwards on the black tab.
  7. Dell Inspiron 8600 Touch Pad Replacement: 7 단계, 이미지 2개 중 1개 Dell Inspiron 8600 Touch Pad Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the display module directly upwards from the base of the computer.
  8. Dell Inspiron 8600 Touch Pad Replacement: 8 단계, 이미지 1개 중 1개
    • Now remove the display module.
  9. Dell Inspiron 8600 Touch Pad Replacement, Touch Pad: 9 단계, 이미지 1개 중 1개
    • Remove the palm rest assembly that secures the touch pad from the device.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
8다른 기여자 명과 함께
John Nesthus
회원 가입일: 04/13/11
186 평판
안내서 6개를 작성함
Cal Poly, Team 18-22, Garner Spring 2011 Cal Poly, Team 18-22, Garner Spring 2011 회원
CPSU-GARNER-S11S18G22
4 회원들
안내서 16개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 22
전체 시간: 3,098
