소개
We will show you how to remove the display module which will then allow you to remove the upper case.
도구
부품
지정된 부품이 없습니다.
Insert a spudger into the notch at the far left side of the top blue panel and pry the hinge cover off.
You may need to pry the other side off as well. You can do this by inserting the spudger between the hinge and the top cover.
Using the Phillips #1 remove the screws at the top of the keyboard as indicated.
You will need to pull out the white tab underneath the keyboard upwards until it pops out of its socket.
Flip the laptop over and remove the indicated screws.
Flip the laptop back over.
Find the two places where the display module is attached to the base of the computer.
Remove the two screws that hold the upper case.
You can now pop up the upper case and replace.
다른 한 분이 해당 안내서를 완성하였습니다.
