소개
The screen is one of the most crucial components of a laptop. Without a proper screen, a laptop can be rendered useless. In the event of your Dell Inspiron 910 laptop’s screen isn’t functioning as intended for any reason, this guide will assist in replacing the screen each step at a time. Before using this guide, make sure the laptop is powered off completely to prevent any further damage.
필요한 것
Flip the laptop so the battery is facing upwards.
Push the battery release tabs toward the center of the device.
Remove the battery.
Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
다른 2명이 해당 안내서를 완성하였습니다.
