이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Replacing the screen on a Dell Inspiron 910.
필요한 것
Flip the laptop so the battery is facing upwards.
Push the battery release tabs toward the center of the device.
Remove the battery.
Use a plastic opening tool to pry the silver portion front of the top away from the colored portion.
There should be two screws holding the metal casing that holds the screen. Using your Philips 0 Screwdriver, unscrew them and pull the casing outwards.
NOTE: Keep track of where you put the screws after you remove them. Keep screws of the same size together and away from screws of different sizes.
Pull down the laptop's back; the screen should be left upright, held in place by two metal strips going along its sides.
On either side of these strips there will be two screws. Unscrew them on both sides. While unscrewing the screws on the second side, make sure to hold the screen so that it doesn't fall when the screws are removed.
다른 2명이 해당 안내서를 완성하였습니다.
